Assuming he got the new Sound Digital amp... thats a lot of power for most any 3" coil to take, thermal handling on those subs is not 4500wrms each, it simply does not have the tooling involved to support the airflow that would be needed to cool the amount of heat that coil will have to it. For burps im sure but I know you guys are daily pounders, demoing with 4000-4500wrms to each HDC312 is not something that will work, not for more then a few seconds at least.why would his subs smoke?
Cactus Sounds ELT12what amp?
and you're "assuming" he has the electrical to get 8k out of that amp. Music is much different then tones...Assuming he got the new Sound Digital amp... thats a lot of power for most any 3" coil to take, thermal handling on those subs is not 4500wrms each, it simply does not have the tooling involved to support the airflow that would be needed to cool the amount of heat that coil will have to it. For burps im sure but I know you guys are daily pounders, demoing with 4000-4500wrms to each HDC312 is not something that will work, not for more then a few seconds at least.
Cactus Sounds ELT12
wait until the car is done 2 ELT 12s a few lil batts 4 new stronger 12sthat cactus amp is sick
we don't all like to be tune in the 50's.pretty weak SS 3 4 scores there still louder then my 2900 watts
Well based on the Sound Digital 20MHz CMOS FLASH-based 8-bit microcontroller you really dont need much power at all to produce the output that the amp is rated at, so I have not assumed anything, simply going off of the manufacturers words.and you're "assuming" he has the electrical to get 8k out of that amp. Music is much different then tones...
50s im not in the 50s im in the mid 40s and my truck is in the high 30swe don't all like to be tune in the 50's.
