Cuttout at high volumes
Mattp13
OK I was at school today and lefted for lunch and was bumping out of the parking lot then i lefted school for good and i turned it up and the speakers went out. So i turned it down and the speakers work when it is at low volumes but when it starts to get loud it cuts off. But the sub is still working . Also the amp is on it just isnt putting anything out.
Check input to the amp.....then check ground on the amp and B+
ok just a question why would the amp start cutting out now if it have worked for a while. but i am going to check the ground and how do i check the rcas
It was probably the loose ground. Also, it may be that your battery and/or alt are going bad. I'd have a local auto store test them for you if it still cuts out.
Mattp13
Mattp13
Manassas, VA
Mattp13
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
