Tell me how air can move without a velocity. Is it air that is moving but standing still?
Do you think air in an HVAC system that is running has no velocity?
Do you think either WTC tower could be considered a completely sealed system with no air movement?
So, tell us why you think the stoichiometric ratio of the fire at WTC was at the perfect 14.7 or less, that jet fuel was the only thing burning, and thus why the fire could not melt steel.
And then explain how steel can be melted in a wood fire. While you're at it, also explain why an container can be melted in a campfire if wood only burns at 700F, but aluminum melts at 1,221F.
For extra credit, tell us why it is not possible for the temps inside Notre Dame to have reached 2,500F with nothing more than the building itself feeding the fire.
Same "act of god" that people claim saved the crucifix in there?
Now, tell us how a forest fire can reach upwards of 2,000F with nothing more than live trees (very inefficient fuel) being consumed by flame.
Explain the basics that you think "can't happen" before you get into the conspiracy fantasy crap.
It wasn't the jet fuel, it was the fire started by the jet fuel. And the "majority of the fuel" wasn't consumed by the fireball. They estimate 20,000kg went into the building. That's over 5,000 gallons of jet fuel,
Do you consider that an insignificant amount when it is a fuel source dumped in a somewhat enclosed space, saturating anything porous?
Try this: pour a cup of gas on a rag and light it as fast as you possibly can.
Tell us if the gas just flash-burns off as vapor and leaves the rag untouched, or if the rag itself starts to burn.
But since you are likely an expert from your education, I'll defer to the other experts' explanation. You can then tell us why they are wrong:
."A substantial portion of the fuel got burned in the initial fireball on the exterior, which suggests that the fuel volume that was ignited in the interior of the towers may have been on the order of 25 m3, or about 20,000 kg. It should be remembered, however, that the initial fireball contributed to the heating of the building and the ignition of some of its flammable material. The enthalpy of reaction of the fuel, that is the heat generated as the fuel is burned under stoichiometric conditions in air, is almost 45 MJ/kg of fuel. Thus, for a plane fueled to capacity (72,000 kg), the total heat load (the heat generated if all the fuel is burned) is a staggering 3,240 GJ (giga-Joules). Burning this fuel continuously over a period of almost an hour, this energy generates a power of almost one gigawatt, equivalent to the power of a large conventional or nuclear power plant. A small fraction of this power is indeed capable of causing enormous damage if unleashed close to a building."
After you debunk the folks of MIT, please explain how this stainless chimney liner is glowing orange (indicating a temp in the range of 1,600-1,900F) when it is connected to a woodstove. Wood burns at 700F in free air.
Try to speak to facts and evidence, even scientific principles, in your explanation.
A typical useless and meaningless response.
No, it's the same MIT that helped create the vaccine that made your body a magnetic 5G tower full of nanobots.
They are funded by 100 y.o. astral-projecting Nazis who were resurrected from the dead and brought here by Bill Gates and IBM in order to conquer the world.
They work in pyramids hidden in caverns under the campus.
