crystal good? need opinoins on comps
  • 3
buthatsabuick
OKC
hi, im looking for a good 5.25" components set, i will have cdt 61as in the rear and want just as good sound upfront. ive been looking at alpine mb quart and crystal. the comps will have 100w on them constantly every day in a daily driver...so something around 10w rms. pretty much looking for suggestions thanks..
i have heard that mb quart mids have little to no bass.
how are these?
http://www.sounddomain.com/sku/CRYCSC50T
Well....I would just put those CDT's up front and leave it at that....but if you're so inclined to go the other way....why not just get another pair of the CDT's? Those Crystals are only 70RMS....not a good idea to run 100 to them.....
see i dont have a problem with cutting my door but i have a mounting depth problem. i only have 2.5" MD and the cdts are 3". any way to work around or solve that?
actually instead of cutting my door...could i cut a square out of .5" mdf and just mount the speaker to the mdf and the mdf to the door? i have done this with 6x9s in the rear of cars before but i dont work with doors often.
Originally posted by buthatsabuick actually instead of cutting my door...could i cut a square out of .5" mdf and just mount the speaker to the mdf and the mdf to the door?
That's what an MDF mounting ring is //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can make it work. Make those mounting rings and whatever else you need. It might take awhile
but you'll get it done.
I just finished installing crystal csc60 6.5" mids in the doors of my 90 civic.
The stock mounting depth is only around 1 5/8". The crystals require 2 1/2".
Not only that but they would not fit under the door skin even with a mounting plate and a mounting ring.
I had to make 2 mounting plates, glue them together and screw them into the door. Then
put the skin back on minus the kickpanel. Then put a ring on mounted off-axis over the door skin with 3 shims
in between all at different angles/heights to support the off axis ring.
So all together, 4 mounting plates, 2 mounting rings, 6 shims, 24 screws, and many hours later the crystal mids are finally sitting in the doors!
Tomorrow i have to wire them.. I wanted to do the fabrication stuff first because i knew it was gonna be harder.
Next time i'll save an extra $200 and buy some kodas!
The fun never ends. Enjoy.
Dont know yet. Theyve only seen power from the HU just to test for signs of life.
Wires go in tomorrow.
Coustic amp gets here next weekend. I'll let you know when i get everything hooked up, maybe throw in some pics.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
213
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
179
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
510
buthatsabuick
buthatsabuick
OKC
1zenlunatic
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
