Crunk Flammable Jello Times
Then youll be more depressed with the Eclipse.
BTW .. so your sending a clipped signal to the sensitive inputs of the amp. How does that make the amp bad?
No clipped signal. 23/35 on a 7998 with no eq or mx just crossovers set is not clipping
It was a hunk of poo and couldnt take a beating.
No clipped signal. 23/35 on a 7998 with no eq or mx just crossovers set is not clippingIt was a hunk of poo and couldnt take a beating.
Oh boy, I wont debate this with you. 1 in 4537846597069 people disatisfied sits fine with me. You werent happy, its all good. But remember the signal is what clips the amp. And by God Alpines never clip when theyre at half+ volume. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Im personally not offended at all. I know thats not your intent. Just clearing the air on the 'clipping' issue.
I had the same problem with my AV6 when I ran the OE Navi HU. After a few talks with Brad and two amps later it was determined to be my signal. After adding my processor, the problem Never occured again. The input stages on the 2500 specifically are Very sensitive.
I talked to him to, he said the same thing.
I actually tried my 2500 on a kenwood and it did the same thing.
The imput stage is much to sensitive.
BTW, lack of desired output is fine, but it does do what it claims. Your just a basshead. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
When you have the room why not use it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I like my music loud as piss at times but I never clip anything.
UndercoverPunk
DOT
UndercoverPunk
Dayton, OH™
mahc
