Crossfire cfa1000d orion hcca 225 gen 2
mclerico83
both fully working
125 each shipped
200 for both shipped
shipping included in price
cfa1000d does 1k at 1 ohm rated at 12.5 watts made in usa beautiful amp old school 1999
1 x 250W @ 4 ohms (12.5V)
1 x 500W @ 2 ohms (12.5V)
1 x 1000W @ 1 ohm (12.5V)
orion 225 hcca way underated old school amp
Output Power at 12.5V:
2 x 25W @ 4 ohms
2 x 50W @ 2 ohms
2 x 100W @ 1 ohm
2 x 200W @ ½ ohm
1 x 100W @ 4 ohms bridged
1 x 200W @ 2 ohms bridged
1 x 400W @ 1 ohm bridged
THD: 0.03%
S/N Ratio: 110dB
Fuse: External 35A
Freq. Response: 6Hz ∼ 20kHz (±0.5dB)
Dimensions: 11" x 8.5" x 2.25" (28cm x 21.6cm x 5.7cm)
Sniff. Snifff.....
Used to own an example of the 225. 1/2 ohm stable.
from memory..
25X2 @ 4 ohms
50X2 @ 2 ohms
100X2 @ 1 ohm
200X2 @ .5 ohm
And it's bridgeable so 100 @ 4, 200 @ 2, and 400 @ 1.
I used mine for highs and loved it. never ran at 1/2 but saw setups that did...runs very hot but works. Don't think I would run "daily" @ 1/2 ohm.
I consider the 225 the original cheater amp. (Rated at 50 and produces 400!)
yea i had an orion 225 and 250, ran the 250 as a mono at 1 ohm and the thing slammed, rated at 100 watts and put out over 1000
---------- Post added at 10:20 PM ---------- Previous post was at 10:20 PM ----------
JL coaxials' date=' A couple 4 channels, some Neo shallow 8's, and OS sony ES deck...[/quote']
not really interested
the Orion will need a bridging module to be able to bridge it...but it is under rated I think tested they will pull about 550 into 1ohm...with old school efficient speakers...they were impressive
no bridging module needed, this is gen 2, has a button on the side to switch to mono.
mclerico83
mclerico83
tampa
mclerico83
