Sold Critical Mass LS 152 shallow mount subs
kmanian
I have 2 Critical Mass LS 152
15" Neo shallow mount subs, that I really want to hold on to, but my wife say otherwise.
These don't come up often, hence my sadness in letting them go.
Specs from the CM site
TECHNICAL INFORMATION:
Speaker Size : 15"
Voice Coil : 3"
Max Power Handling : 2000 W
RMS Power Handling : 1100 W
Fs : 28 Hz
Znom : 2 Ohms
Linear Xmax p-p : 25.4 mm
SPL : 94 dB/2.83V
Motor : NEO
FEATURES :
Thin Mount Design:
Allows for custom shallow depth box designs.
Lightweight Design:
Weighs up to 66% less than most other High Power Subwoofers.
Huge NEO Motor structure:
Up to 20 times more magnetic charge than standard magnets.
Huge 3" Multi Layer Voice Coil:
More than 3 times the power-handling of other shallow Depth Woofers.
Multiport Vented Motor structure:
Increased Long term power handling.
Inverted Motor structure:
Further increases long term power handling and allows for shallow mounting depth.
Woven Carbon/Glass Fiber Cone:
Increased Power to Weight ratio.
Designed for Ultra small Sealed or small vented Boxes:
1.0 qft (requires 1100W for full output)
1.25 qft (requires 900W for full output)
1.5 qft vented at 48 Hz (requires 500W for full output)
I will post pics with user name tomorrow.
I am asking $400 each
Cash is king, but trades are possible
Hi, coming off from 2 13W7s, how will this compare, in loudness in a sealed box?
diffrent beast for sure, it is comparing apples and pears.
The SQ is top notch, arguably better than a w7, but spl, the w7 hands down
but you can put thes in spaces you would never get a w7 into and use really small sealed boxes
kmanian
kmanian
Grand Cayman
kmanian
