Sold Critical Mass LS 10 Thin sub!!!
kmanian
I have one LS 10 thin line sub that I am not going to be using, I will get pics up tomorrow, I am looking for $350 for it.
The LS series of subwoofers represents vast improvements over other shallow mount speakers. This is the lightest, shallow mount, high power handling woofer of its kind. With power handling exceeding 1000 Watts, you simply can’t find any competition for this subwoofer. Designed to work in both extremely small sealed and small vented enclosures, this woofer has something to offer everyone. Accurate, powerful, and thin, the LS series boasts over 12mm of Xmax. Critical MASS engineering at its best!
TECHNICAL INFORMATION:
3.5" mounting depth
Speaker Size : 10"
Voice Coil : 3"
Max Power Handling : 1500 W
RMS Power Handling : 900 W
Fs : 32 Hz
Znom : 2 Ohms
Linear Xmax p-p : 25.4 mm
SPL : 91 dB/2.83V
Motor : NEO
FEATURES :
Thin Mount Design:
Allows for custom shallow depth box designs.
Lightweight Design:
Weighs up to 66% less than most other High Power Subwoofers.
Huge NEO Motor structure:
Up to 20 times more magnetic charge than standard magnets.
Huge 3" Multi Layer Voice Coil:
More than 3 times the power-handling of other shallow Depth Woofers.
Multiport Vented Motor structure:
Increased Long term power handling.
Inverted Motor structure:
Further increases long term power handling and allows for shallow mounting depth.
Woven Carbon/Glass Fiber Cone:
Increased Power to Weight ratio.
Designed for Ultra small Sealed, or small vented Boxes:
.5 qft (requires 900W for full output)
.75 qft (requires 700W for full output)
.75 qft vented at 52 Hz (requires 300W for full output)
thats a real interesting design and the rms is really high. thats pretty sweet. but personally, i like big subs that will rattle your ****ing brains out //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
kmanian
kmanian
Grand Cayman
Sween
