Creating LPF circuit for rear fill decode schematic
Oraclem19
Need a little help getting this schematic figured out, most of it is understood with the exception of the triangular objects(amps-opamps?)
Not sure what those are or how to implement and order them. Here is the diagram thus far(planning to test with a lpf at 1k and 500, with the hpf staying around 80-100hz)
Thank you for any help.
The triangle things are opamps, any generic part would do. But the circuit assumes a split +/- power supply which you don't have. It's also much simplified and not detailed enough to be practical. A real circuit would have bypass caps on the power supplies and a coupling cap at the input etc.
Oraclem19
Oraclem19
United States
bubbagumper6
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
