Converting AVI to VOB (DVD) without audio/video issues and quality loss
Do you want to convert AVI files to VOB so that you can burn them on a blank DVD and then play them on your DVD player? According to my own experience, the professional and powerful program called Moyea Video Converter can enable you to convert AVI to VOB perfectly.
The following tutorial will show you the step-by-step guide about how to convert AVI to VOB with Moyea Video Converter.
Preparation: Free download Moyea Video Converter here, install and run it.
Step 1: Add AVI files into this AVI to VOB Converter program.
Step 2: Set output video format and destination folder
Click the drop-down list “Format” you can select the output video format as VOB. At the same time, you can set the destination folder by clicking the “Output” if you don’t need the default output folder the program offers.
Step 3: Customize effects (Optional)
Click the “Edit” button to open the editing window. Then you can customize the output audio and video.
Under the “Effect”, you can drag the slide bars “Brightness”, “Contrast” or “Saturation” for a better visual effect. Drag “Volume” slide to adjust volume.
Step 4: Set advanced settings (Optional)
Click the “Settings” button on the main interface, a profile window will pop. Then you can make detailed settings for output audio and video, like audio and video codec, bit rate, video frame rate, video size, audio channels, etc.
Step 5: Convert
Okay, now you just need to start converting by clicking the “Convert” button. The whole conversion task will do in a little time for its multi-thread encoding technology which enable convert AVI to VOB with 1 or 1.5 times faster than other similar tools on the market.
See, it is really easy, isn’t it?
Step 5: Convert
