Kinda of a newb question but.......
If I add more subs (cone are) with the same power will I get a increase in Bass (spl or sq)?
Running 2 Ti PG dvc 10's on two older z1000d mono amps @ 2 ohm. Over powering them by around 250w according the the amp and sub specs so I have some power to spare on a low end pair of 10's.
So... if I keep the two amps running @ 2 ohm (500-750rms) with the two 10's and add another pair of 10's will I see a increase in Bass (spl or sq)?
Note: Will have 2 subs in two seperate sealed boxes (total of 4 10's). I know these amps will put out (had them pushing 4 12" type r). Had to go with two boxes so I can pull them out for road trips (kids in the back seat). Oh yea 02 2500 quad cab.
Considering replacing the 2 PG and going with 4 Lanzar or 4 Massive Audio low end subs.
OR.................................
Drop 300 bucks on 1 12" or 1 15", and run 1000w rms on one hi end sub? manual says I can hook the amps together. shouldnt matter either way on the amp though - think I will get more power if I stay @ a 2 ohm load vs hooking them together.
Dont know if this has beed discussed and sorry for not using the search but I plan on buying on Friday.
Thanks all
Thanks all
