Sold Cleaning out the garage again
AVX Mike
Old School Soundstream MC245 $225 plus shipping
5 channel amp
Great working condition
SPECIFICATIONS Power Output
MC245 5 Channel - Xw x 4, plus 1 OOw x I2,0Hz-2OkHz, into 4 ohms
4 Channel - 35~ x 2, plus 9Ow x 1, plus 1 OOw x 1,20Hz-20kHz, into 4 ohms
3 Channel - 9Ow x 2, plus 1 OOw x 1,20Hz-20kHz, into 4 ohms
THD: ~0.1%~ 20Hz-20kHz at fuII rated ouput into 4 ohms
S/N Ratio: 1OOdB
Damping Factor: >200
Input Impedance: 10 kOhm
input Sensitivity: 250mV-29
Idle Current Draw: 1.5 A
Maximum Current Draw: 30 A
Dimensions: 13 -l/8” W x 7- 13/ 16” D x 2-l/8” H (including mounting flange)
Audison SRx2 2 channel amp $100 plus shipping
POWER SUPPLY
Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC
Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 A
Idling current when off: . . . . . . . . . . . . . . 0.002 mA
Musical max consumption: . . . . . . . . . . . . . . . 15 A
AMPLIFIER STAGE
Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.05 %
Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 150
Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V
Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V
Pre In input impedance: . . . . . . . . . . . . . 15 kOhms
Speakers In input impedance: . . . . . . . . . 100 Ohms
LOAD IMPEDANCE:
- 2 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms
- 1 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms: . . . . . . 45W x 2
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 65W x 2
- 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . . 85W x 2
- 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 170W x 1
FILTERS/INPUTS
Inputs: . . . . . . . . . . . . . . . . . . Pre In / Speakers In
Filters: . . . . . . 12dB/Oct., bypass / hi-pass / lo-pass
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . (50÷220) Hz
OTHER FUNCTIONS
Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA
Connections for VSR kit
for SUB remote volume: . . . . . . . . . . . . . optional kit
Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . blade, 20 A
Protection: . . . . . . . . . . . . . . . . temperature >85°C,
DC voltage, overload
Green-red LED indicators: . . . . . . . . . . . . on-safety
MAX SIZE (D x H x L): . . . . .178 x 49.5 x 210 mm
WEIGHT: . . . . . . . . . . . . . . . . . . . . . . . . . . .1.5 kg
2-15" Eclipse Ti motors and baskets $115 each o.b.o. plus shipping
180 amp Ohio Generator High Output alternator for 95-99 non turbo Eclipse (420a). $400 obo
Also fits talons, sebrings, and avengers with the same motor. I only used it for about 4 months last year. With a MMATS 3500.05, two g31 optima batteries and on g34/78 optima my voltage drop was only .2 volts at full tilt. Great alternator from a great company.
Clifford Matrix 2.5x alarm $100 o.b.o.
2 way LCD responder alarm
AVX Mike
AVX Mike
Waite Park, MN
rosrock
