Sold Clean Mmats D300hc Factory Modified
dadon
What can I say here: Mmats is mmats, awesome equipment. Very small foot print, beefed up to produce 2600 watts at 2 ohms by the factory. The amp is in nearly mint shape, has one small nick as seen in the pictures. To compensate for that, reduced to 300 shipped to your door for this amp... Way below what you can buy this from anywhere. This amp was used sparingly then sat looking beautiful in a display case. See pics below. Amp is boxed and ready to ship out today, 2600 watts for 300 dollars.. you can't find that anywhere, let alone from an mmats amp.
See pictures below: http://www.caraudio.com/forum/showthread.php?t=426024
again the amp has been modified read the initial post. mmats made these amps custom, there are a few on here that will do down to .5.. mine won't but they are out there
i wouldn't expect over 2600 from it rms, maybe more peak, but i don't want to over quote it. I do know it will do around 2600 no problem
Ive got one factory modded with blown fets that would do half ohm all day with sufficient power backing it up,and quarter ohm for burps.This one should be able to do the same since there was only one type of mod avail. from factory years ago.
dadon
dadon
missouri
dadon
