"Bench testing", at least how I use the term, means you're using a stable power supply that won't drop like an overtaxed charging system might, and you're driving the amplifier into a purely resistive load, not a speaker that has both inductive and resistive components that depend on frequency.So what's the difference between using a clamp meter or getting your amp bench tested?
V=IR
P=IV
lol, i know that. I was just confirming what you said was right.lol that's exactly wat i said. In Ohms law the V is E. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Expect to spend $70-$150 on a good meter...
My Harbor Freight clamp is just as good as anything else I've ever used.
I also have a Clarke-Hess RMS power meter that I have compared it to and it gives the same exact results. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Twenny Dolla http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42397
WTF do you think it's used for in car audio then?Theres another use for a clamp meter, and thats to measure DC amperage. You can see much actual current you are drawing from the alt.
I dont see many clamp meters that measure DC current tho.
Somebody asked what the uses of a clamp meter are. There is the use of more closley calculating your output power from your amp. There is ALSO the use of measuring DC current, like I stated above. I was simply imforming the other uses of a clamp meter. And measuring DC current in your car can be helpful. My rebuilt alt was acting up. I pulled out a clamp meter, and measured total amperage draw, which was about 80 amps at full volume. The alt was supposed to be able to put out 130 Amps. And at full volume, I had voltage drops down to 12.5v.WTF do you think it's used for in car audio then?
