Originally posted by maylar Circuitbreakers are desireable where fuse replacement is extremely inconvenient. But good ones cost a lot more than fuses. That's why they aren't used in cars. As for reliability, I disagree with the general consensus... there are no fuses on the Space Shuttle, on any aircraft, or on any ship.
Umm..
This is not an aircraft, not a ship, and it WILL NOT be in a controlled environment like the others will be. If you are installing this the way you are
*supposed* to, it will be less than 18" from the battery. Subjected to ice, dirt, rain, slush, and every temperature variance possible.
Flat out reason fuses are used: THEY ARE SAFER. A circuit breaker has moving parts, that CAN fail. They have failed, and I still have the unit that chose to fail. It nearly started a fire in my car. It's hanging on my wall as a reminder to forget the pretty resetting garbage.
Your attempt at a comparison is completely inaccurate, carefully note how the circuit breakers are installed in ALL of these places. Outside they are all enclosed in a nema4x enclosure or the equivalent, inside they are still enclosed to protect from the environment.
If you want to get *really* technical, places with heavy power demands use a 400 amp
fused panel to feed the separate circuit breaker panels. Want to know why, call up your local electrical inspector and ask some questions.
