Chassy grounding location
QuadinExploder
Aspiring Deaf *** Mofo
i have both my amps wired to the same spot in the cargo area. i drilled a hole in the floor and ran a bolt through after scratching the paint off. the thing is that the floor metal seems kinda thin. im wondering does it make a difference whether you groung it to 1/8" thick sheet metal, or would it be better to groung to something more substantial?
eclipse 32330 300w
kicker zx1500.1
2 kicker 12 L7's
4 pioneer 3-way's
so u drilled scrapped cleaned and used a star washer ? aslong as u get no noise and u like the outcome u good to go. but u should test the ground point with ur dmm b4 u drill and put down.
QuadinExploder
QuadinExploder
largo,fl
QuadinExploder
