chaining 2 a3000's
bamaboy
War Eagle!!!
how do you hook up 2 of these this makes it seem a little wierd, what i wanted to do is wire an amp to each coild this has you connecting the negatives and putting one pos on the negative terminal
how would you just hook an amp to each coil, and set it right it would be really hard with a dmm, how could i just connect the cable to it and run a pos and neg from each amp to a different coil
iIf you only want 1400 out of each one, you dont need to have it at .7 ohms. If it would run on .7 ohms is really iffy too, the yare rated at one, and PA isnt exactly known for running cold....
I think that you should listen to what scottie Johnson said about the leads of your DMM. That woofer is dual .7 and the A3000's will pur like kittens all day long at .7 ohms mono. I think you're making this a lot harder than it really is. Call me and I will help you set everything up.
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
InhumanAcura
