Sold Cerwin Vega Stroker *old style* F/S/T
chromie
Ive got a 15" Cerwin Vega Stroker just like the title says and its the old version and the sub weighs about 36lbs
It has some cracks in the surround but they were filled with black silicone and they dont effect the performance at all
Has a homemade box i built ill get exact dimensions next week cuz i forget and my truck is in the body shop right now but its somewhere around 5 cu. ft. with 2 4" round ports 16" long each ... and dimensions are around 22"x20"22" ... the box is NOT carpeted ... i didnt get to that ... the box is built with 3/4" mdf wood
cosmetically 8/10
Specs:
FREQUENCY:30-200Hz
POWER HANDLING:
Single: 1,200 watts
Dual: 600 watts per
voice coil (continuous
unclipped power per
EIA RS-426C)
NOMINAL IMPEDANCE:
Single: 4 ohms
Dual: (2) 2 ohms or
(1) 1 ohms or
(1) 4 ohms
SENSITIVITY:
95 dB
(1 watt - 1 meter)
VOICE COIL DIAM.:
3.0"
MAGNET ASSEMBLY:
25 lb, 2 oz
(11.40 kg)
TOTAL WEIGHT:
31 lb, 4 oz
(14.18 kg)
MOUNTING DIAMETER:
14" (35.6 cm)
MOUNTING DEPTH:
7 1/8" (18.1 cm)
Pics:
Price:$300 shipped with box
$200 shipped with out box
lol thank you ... i cant believe i had everything else but the size ... you can tell from the box dimensions if you think about it lol its a 15
I found one of these strokers at a pawn shop near by. They want 120 for it, with the large vented mdf box included. I had them hook it up and it plays, though they were only using a computer power supply.
I am posting this just seeking advise. The cone has a hairline crack nearly all the way around about 1/2 inch from the surround. The crack is not all the way through.
The inner spider, I mean around where you would normally find a dust cover, is intact but does not seem to be perfectly symmetrical. I mean, it has not been repaired, but it... well actually it looks fine. No voice coil rubbing at all.
That adjustment nut in the center, I guess that is what it is, seems to be shorter on this driver than in all the pictures I have been able to find. Has someone dialed it in to reduce the x-travel? I don't even know how these things work. I am just considering driving down there to make an offer.
How does this sound to you guys? Worth the risk?
I wish I had pictures but I don't.
Thanks.
CT
chromie
chromie
Aston, PA
cary_todd
