cerwin vega stealth 220.2 guts
Reimers
i promised to post pics earlier but forgot about it. so here they are
specs
4 ohms: 65 watts x 2 chan.
2 ohms: 110 watts x 2 chan.
Bridged, 4 ohms: 220 watts x 1 chan.
Dimensions: 6-3/5"L x 7"W x 1-7/8"H
yes 25A fusing. im very satisfied with the power it puts out for its size.
im using it to power a pair of cerwin vega vmax 6.5 component speakers
why? because they make cheap smaller amps aswell as bigger and more expencive amps?
here is a stroker2000.1 do you think it looks bad to?
why? because they make cheap smaller amps aswell as bigger and more expencive amps?here is a stroker2000.1 do you think it looks bad to?
well honestly the little 65w amp is beastly...the 2k...i may be spoiled by my amps guts but it doesnt seem all that great
a guy on diyma clamped the 2kw one
Clamp results are in...
Set with O-Scope to the clean side of a soft clip. 50hz tone. True RMS clamp not on peak hold. One Kinetic hc1200.
2,250w rising to 1.52ohms with voltage drop to 12.5v.
Reimers
Reimers
Norway
AStovall
