CDT Satnet 560 Crossovers & EF-61 Midrange woofers Package
Both the crossovers and midrange woofers are in excellent condition. One of the midranges has a chiped basket and some adhesive on the cone but it doesn't affect the performance.
$125 + shipping & fees
EF-61 Midrange Woofers:
http://www.cdtaudio.com/hd62ef.htm
6.5" Cast Carbon Treated Paper Cone
120 watt RMS
60-20kHz
90.5 dB.
4 Ohm
http://www.cdtaudio.com/satnet456-642.htm
Satnet 560 is a cut above the all the above models. In this model the high pass crossover is replaced with a fourth order transient-optimized design. This delivers the cleanest possible tweeter drive. Crossover takes place at a slightly lower 3.7kHz.The first order woofer crossover has a larger zobel capacitor for a lower crossover frequency to match. More than this a tapped inductor adds adjustability to this woofer crossover also. This suits different driver sizes generally. The adjustor is labeled by driver size (5.25 and 6.5). The image tweeter is operated 3 db below the main tweeter at a fixed attenuation. Protection is omitted for maximum sound quality. Terminals are 12 gauge block terminal, more robust and arranged in a dual four arrangement versus a single line as in the prior models.
120 watt RMS
60-20kHz
90.5 dB.
4 Ohm
