CDT ES-010WD Wide Band Wide Dispersion BNIB
wanderer1
Item(s) for Sale: CDT ES-010WD 2" wide band midrange tweeter. ( I can make a 2 way or 3 way system using these for you with all new CDT drivers. Just paired with a 6.5 would be all it would take)
Item(s) Description/Condition: ES-010WD is the most advanced transient perfect ferromagnetic oil-cooled tweeter driver in the market with clean smooth and gentle response. A very pleasant sounding tweeter for use in any position where it fits. Its aluminum anodized casing create a wide dispersion pattern. Wider dispersion than any other tweeter driver of its kind. This unique enhanced wide dispersion tweeter driver is optimized for all automotive sound systems and of course integrates perfectly with other CDT components. •1.1" Silk ultra wide dispersion dome Tweeter Ferro fluid cooling
•Neo charged magnet structure
•Frequency response 1500Hz-21.000Hz
•Nominal impedance: 6 Ohm
•Sensitivity:90.dB
•Powerhandling:50-100watt
•400watt short term max
•Dome: cloth silk
•Cast aluminum driver housing
•Flush mounting housing
•Bezel diameter (OD): 2 12/16”
•Mounting hole: 2 7/16”
Retail $249.99 before shipping and Tax/ Condition 10/10 BNIB
Price: $200 shipped and paypal
N/A
couple of questions. Ive not used a widebander before so Ive been reading of others that use them.
1st does this need to be placed on axis to get good response? I see some widebanders are just glorified mids that play a bit higher, so would I need to use a tweeter with this? What to make sure the high end still good? I used to like old school large format tweeters so I think this is going to be close playing from 2000 up?
how do you have yours mounted? The way my a pillars are they would have to mount off axis and fire across the dash at each other. I know some widebanders dont have any high end when they mount that way. Some say you dont get the tweeter sound depending on the speaker. interested but want to make sure they work for my install.
wanderer1
wanderer1
Laughlin
wanderer1
