CDT CL-6SL Super Shallow 6.25" Mids
trumpet
Barry Schanz
CDT CL-6SL pair
Used 8.5/10
6.25" Mid-Woofer Pair
This was designed for those extremely tight situations where a normal woofer simply will not fit without cutting into the vehicle.
1.5" Mounting Depth!
Technical specs and contents:
  • 1 pr 6.25” super slim mid-woofers
  • Frequency response 100 Hz - 5,000 Hz
  • Power handling: 50 watts (90 watts Pk)
  • Power handling: HPF 120 Hz 100 watts RMS
  • Impedance: 4 ohms
  • Sensitivity: 86.4 dB
  • Mounting depth: 1.5”
  • Cut out diameter: 5.19”
  • Cast frame: OD 6.25”
  • Cone: Honeycomb matrix
  • Magnet weight: 20 Oz
  • Cone surround: rubber
  • Voice coil: 1.0” (25.4mm)
  • Fs: 73.5 Hz
$99
Free shipping to the lower 48 states.
Shipping to other areas is available. Ask me for a quote.
Any similar used 2-ohm 6.5's?
No used 2 ohm 6.5s. What I can offer is HD-6CF, 2 ohm, new. 2.4" mounting depth, 80W RMS, carbon fiber cones with an aluminum phase plug. Stepping up from that we have ES-6CV, from the ES Gold line. 200W RMS crossed at 100 Hz, 2.75" depth, kevlar/fiberglass cone.
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
