CDT Audio MA-3001 Monoblock
  • Thread starter trumpet
  • Replies 0
  • Views 1K
trumpet
Barry Schanz
CDT Audio MA-3001 Monoblock amplifier
1 available
New, slight cosmetic flaws
Class AB design
Features:
  • MOSFET power supply
  • Plated brass set screw terminals
  • 12 dB/octave crossovers
  • variable low pass crossover (30 Hz - 500 Hz)
  • Subsonic filter
  • Variable 0 dB to 12 dB bass EQ at 45 Hz
  • 5 Way Protections
  • Daisy chain through output RCA
  • Power and protection LED
  • 2 ohm stable
  • Soft start/mute circuit
Technical specs and contents
  • Power Output:
  • RMS @ 4 Ohm: 220W x 1
  • RMS @ 2 Ohm: 350W x 1
  • S/N Ratio: >95dB
  • THD: 0.05%
  • Channel separation: >50dB
  • Input sensitivity: 0.2V-6V
  • Input impedance: 47KOhm
  • Slew rate: 10V/msec
  • Damping factor: >100 At 4 Ohm
  • Fuse rating: 40A
Dimensions
  • Width: 139.5mm
  • Height: 46.7 mm
  • Length: 220. mm
$250 shipped to the lower 48 states
Worldwide shipping is available. PM me for a quote.
Get 2 MA line amplifiers for $425 shipped.
Buy 3 MA line amplifiers, the 4ch, the 2ch, and the monoblock, all for $600 shipped.
All 3 models have the exact same physical dimensions. This makes your system layout symmetrical and easy to design.
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
