CDT Audio DRT-26A Aluminum Quick Swap 1" tweeters
  • 1
trumpet
Barry Schanz
CDT Audio DRT-26A Modular Aluminum Quick Swap 1" tweeters
NIB
Why would you want options for tweeters?
We get bored. Curious to try something else. Would I be happier with different tweeters?
This set gives you the foundation of the Quick Swap hardware plus one of the favorites, the aluminum dome option.
Introducing The DRT-26 1” Modular Quick Removable Tweeter design
Free yourself of fixed restrictions
and introduce the possibility of choice of taste into your life.
The Modular Removable Tweeter Characteristics:
The three modular Tweeters are provided with special mounting options for installation in doors, on the dash and the A-Pillar area. These are available in any or all of three types:
Silk
Aluminum
Titanium
Here’s how it works: You change the Tweeter driver from silk to aluminum to titanium, whatever flavor you choose, with the quick-connect patented design. Now you have introduced the possibility of choice of taste into your musical life. Each type has slightly different qualities. All have their virtues, but there is a different emphasis. The Silk dome is the smoothest. Always gentle and forgiving, this tweeter emphasizes the music and avoids noise and artifacts that may be embedded in some source material, or be characteristic of less than perfect amplifiers. Very low listening fatigue and a sounds-great quality that puts an emphasis on the systems midrange.
The Aluminum is more aggressive at retrieving fine detail. Cleaner and more revealing than the silk but more critical also. The lower end (in a Tweeter) is perhaps the lowest in distortion. The all-around choice. The Titanium is the speed demon. For those who demand the maximum air and energy, the Titanium takes the top end into the violet. Very critical and revealing of high end details. The trio may be snapped into the same housing for an instant A-B. Free yourself of fixed restrictions and introduce the possibility of choice into your life.
DRT 26
1” Modular tweeter ferro fluid cooling
Technical specs and contents:
  • 1 pair 1” modular tweeter drivers w/ neo charged magnet structure (aluminum, – silk, or titanium optional flavors)
  • 1 pair flush mount housings w/hardware
  • 1 pair angled flush mount rings
  • 1 pair flat surface mount cups
  • 1 pair angled surface mount cups
  • Frequency response: 1,500Hz-21,000Hz
  • Impedance: 4 ohms
  • Sensitivity: 92dB
  • Flush mount hole: 1 5/8”
  • Flush mount depth: ¾”
  • Flush cup OD: 2”
http://www.cdtdealer.com/rubyserv/item.php?id=drt26
If you pay me directly I will cover the shipping to the lower 48 states. The web site adds a shipping charge based on your location.
Add the other two flavors, silk and titanium, for just $100 today.
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
audiobaun
    May 19, 2024
    May 19, 2024
