Car audio suddenly has issues
  • 5
JoeZ
Tampa
Hey all, I'm sort of at a loss right now for fixing my car audio setup.  This was all working fine for years, but suddenly got really distorted, then died all together.
I have a sub in the back, with audio coming from a Sub line out on the HU.  This is working fine.  I'm using Front Line Out on HU to a 4 channel amp (only using front channel).  This feeds into L and R filter for tweeters and speakers.  I'm getting no audio out of the 4 channel amp all of a sudden.  When I hook the sub into the Front Line Out, I can hear the sub working.  If I bypass the amp and filters, hooking the speakers into the SPEAKER OUT, then I have audio.  I checked for continuity on the lines, all good.  I bypassed the filters...still nothing.  I replaced the amp...still nothing.  Power light on amp is on when radio is turned on.
Is there anything I could be missing here?
Clarify you are using filter to refer to a passive crossover that divides the audio signal to tweeters and woofers in a component system.
Clarify that this sentence:
Means you connected the head unit speaker outputs to the speakers and have music.  Is this with the crossovers (i.e. filters) or without?  Do the speakers work on the head unit with the crossovers (filters)?
Picture of the 4ch amp connections?
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
391
80a Alt. is your problem....i have a 2017 spark, no way i would go over 1000rms on stock electrical in that thing....and your cap aint doin...
79
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
246
16
658
JoeZ
JoeZ
Tampa
Haunz
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
