Can i do this?
ws140
~`[]D[]][\/]][[]D`~
695
MA
Can i hook my car speakers to my home theater system? My home amp has 8ohm impendence. If i hook up a speaker to two seperate channels will the amp blow? I think it should work but just checking.
I don't think you want 2 channels to one speaker.. that won't work I don't think.. If you had one channel to (2) 4 ohm speakers, you could probably wire them to 8ohm.. you would need 4 speakers instead of 2... (unless they are dual voice coil 4 ohm.. then you can wire each to 8 ohm)..
I could be wrong.. Anyone else?
im not exactly sure if there is a change in the standard resistance with component speakers, but if there isnt, then you can wire them in series like you would two normal 4ohm subs,
from amp, + goes to positive on speaker A, - on speaker A goes to + on speaker B, and - on speaker B goes to - on amp (or home receiver)
hope i helped some, but you might wanna double check the resistance of the xovers
-pat
ws140
~`[]D[]][\/]][[]D`~
ws140
MA
ws140
