loudestRiviNLa.
I have 8 Cresecendo mp6 PA 6.5 speakers that I will have installed in my car once I have it modified to take them.
I was wondering instead of using the 2 of the 4 xst2 supertweeters I have, will i be able to use 8 dome tweeters with crossovers to run with the mp6's to make them into something like 2 way component speakers?
The idea is to make it more easier to use either 2 or 4 channel amps like the Crescendo c1600.2,Lanzar opti250x4,or opti700x2 which are my options that can properly power them without conflicting with the difference in ohm loads and power ratings between the speakers and tweeters.
I would also like to use the same amp for my mids and highs without having to use a seperate amp to run only my highs but I will do so if i need to.
If I can use 8 dome tweeters and crossovers to each of the speakers making each tweeter/crossover per speaker a 2 way driver, that would be sweet!!!
That way, I can use the 4 xst2's when I begin on another build when I get a second vehicle (suv).
Anyway, I hope you all can understand what i'm asking and help out.
Thanks friends
Thanks friends
