Ok i have a giant workbook of problems due for my algebra class Friday and I have just about everything done accept this one that im completely lost on. My teachers a dick and doesnt really teach so most of the class i had to learn on my own but this is wayyy over my head so maybe someone here could help me. There are a few crappy pics he drew that will be attached below. The questions are:
You can see arches almost everywhere you look, in windows, entryways, tunnels and bridges. Common arch shapes are semicircles, semiellipses and parabolas. When constructed on a level base, arches are symmetric from left to right.
A semicircular arch has the property that its base is twice as wide as its height. This ratio can be modified by placing a rectangular area under the semicircle, giving a shape known as a Norman arch. This approach gives a tunnel or room a vaulted ceiling. Parabolic arches can also be created to give a more vaulted appearance.
When modeling the following arches set a coordinate system up in such a way that the origin of the coordinate system is the center of the base of the arch.( pictures are the 1st set at bottom of the page)
1) Show that the function that models a semicircular arch of radius r is h(x)= the square root of (r^2)-(x^2). (sorry i dont know how to type sq roots on the comp).
2) Write a function h(x) that models a semicircular arch that is 15 feet tall. How wide is the arch?
3) Write a function n(x) that models a Norman arch that is 15 feet tall and 16 feet wide at the base
4) Parabolic arches are typically modeled by using the function p(x)= H-ax^2, where H is the height of the arch. Write a function p(x) for an arch that is 15 feet tall and 16 feet wide at the base.
5) Would a truck that is 12 feet talland 9 feet wide fit through all three arches? How could you fix any of the arches that are too small so that the truck would fit through? Justify your answer in each case by drawing a detailed picture or constructing a scale model.
6) Pick any one of the window designs and determine the largest rectangle that will fit through the window: show the function that gives the area and also show what the maximum value of the function is using your graphing calculator. (these are the second set of pictures below)
Thank you soooooo much for anyone that can help me with this problem. It is driving me nuts and im sure there are much smarter people out there than me that can figure this thing out. I also might just have some 1/0 and 4 guage cable waiting for anyone that can help me with this.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The pics my teacher gave me are below. THANKS!!
