Sold Cadence ZRS-7000D FS..
jbgarner12
1000 RMSx1 and 1 OHM stable awsome amp!!! In near new condition
Used but in perfect condition..Purchased last year from Cadence directly..
$200 oboPay pal perferred
ZRS-7000D
HIGH POWER CLASS D MONO BLOCK AMPLIFIER
SPECIFICATIONS:
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
Peak Power: 1 x 2000 Watts
Frequency Response: 10Hz - 400Hz
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Dimensions: 12.6" x 9.4" x 2.4"
FEATURES:
High Speed Mosfet Power Supply
Bi-Polar Japanese Sanken Output Devices
Copper Rail PCB Architecture
24 dB Crossover Circuitry
Fully Adjustable Low Pass Crossover
Low Pass Crossover: 50Hz - 150Hz
Bass Boost Equalization: 0-18db @ 45Hz
Subsonic Filter: 15Hz - 40Hz
Lucite Encapsulated Large 4 Gauge Terminals
Soft Start Mute & Delay
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
Includes Dash Board Bass Remote
jbgarner12@msn.com
Have any better pics and or refs?
If I did this, would either want shipped to me then I would send out money order, or split it. I send you half, then you send amp, then I send the rest. I have done plenty of business on here and looks like you have not.
If you are ok with that, I may snatch it up.
No way... Here is my ebay id you can look it up.. jbcl12 100% positive feed back never a negitive...
If you are unsure use Paypal that way you are covered..I guarentee this amp as near new..
How come you didn't post more pics?
Also I don't do eghey. Sorry if you can't do it that way, then good luck on the sale. I will look else where.
Also LMAO at you being guarentee'd through paypal, lol! Been screwed twice by them assholes!
I can post more but I'm at work right now and the amps are at home..I will post whatever pics you want tonight when I'm off work...Sorry
jbgarner12
jbgarner12
COLORADO
Hintzyboy
