i am selling my cadnce z9000 because i have recently got a new amp. the amp hasnt had much use, id say 3 months total of use. If you want to see pictures you can message me on aim (warmmilkdrinkaz), or email me (AndrewAbuan@gmail.com) or pm me here.
the specs are
2 x 300 Watts @ 2 igns
2 x 400 Watts @ 4 ohms
1 x 800 Watts @ 4 ohms bridged
Frequency Response 10Hz - 40KHz
Signal/Noise Ratio >100dB
Damping Factor > 200 @ 100 Hz
Minimum THD
Channel Separation >65dB
Input Voltage150mV - 8 Volt
i am looking for 150+ shipping.
i also have an eclipse 55040 head unit that has the NOB remote. the head unit needs to be unlocked by eclipse which i was told by a rep should cost around 25 dollars. ill give another call on monday just to make sure. will take some pics if needed. the head unit was purchased from a member from sounddomain. it got locked up when i removed the head unit to transfer cars not knowing that the esn disk was still needed after it was disabled. looking to get 75+ shipping
just remembered i had a pioneer deh1600 that i removed the my car that i recently bought. have no use for it now that i have a new head unit. for this little thing i think ill try letting it go for 30 dollars +shipping. dont know how long it has been owned but i only used it for 2 days and swapped my head unit with it. will have also have pictures soon.
thanks
andrew
the specs are
Minimum THD
thanks
andrew
