Includes:◦2 Speakers
◦2 Crossovers
◦2 Grills
◦mounting and installation hardware
◦Instructions
◦Warranty
Quick Facts about all Ultra-Shock series speakers:
◦The UltraShock Multi-Element Speakers feature an external two-way crossovers. The crossovers utilize audiophile grade, mylar capacitors and inductors for excellent high end transients and smooth high frequency roll off.
◦The tweeters of the US multi-element speakers are 25mm Titanium Dome, with Neodymium magnets. The tweeters swivel at a 15 degree rotation for proper high frequency alignment The voice coils are cooled with magnetic ferro-fluid to keep the heat down and power handling up.
◦UltraShock speaker systems feature die-cast aluminum frames, which encapsulate the entire magnet motor structure. The speaker is vented below the spider line for efficient cooling and increased power handling capabilities.
◦The cones are made of finely woven fiberglass that has been electro chrome plated. The speakers feature our bullet phase plug technology for smooth midbass response. The surrounds are butyl rubber for superior response.
◦US Kit crossovers feature 18dB Zobel circuitry utilizing high-grade audiophile mylar capacitors with air core transformers. Built-in 3dB tweeter equalization system with slide switch control for tunable tweeter response by +/-3dB.
Features:
◦Size: 5.25"
◦4 Ohm
◦25mm Titanium Dome Tweeter
◦swiveling tweeters for soundstaging
◦1.25" High Temperature Kapton Voice Coil
◦RMS Power each: 75
◦150w total RMS
◦Peak Power each: 150
◦300 total peak output
◦Frequency Response: 70Hz-28KHz
◦Sensitivity: 96db @ 1W/1M
◦Mounting Depth: 2.5"
◦Butyl Rubber Surround
◦High Strength Aluminum Cone
◦Die-Cast Aluminum Basket
◦Woven Fiberglass Cones
◦cast aluminum frame
◦Complete with Grills and Mounting Hardware
