Sold Cadence TXA-1000d
connersdad19
I am going to try to put this up for sale for 155 shipped thats with pp fees. The paint is metallic and has a small scratch on it from when i put my box in my car. very good amp i just want to get something a little bigger....this does not have the 4 gauge fuse holder and fuse that comes with it but i have an extra one laying around that i can put with this. here are pre install pics
bump...for specs....
SPECIFICATIONS:
4 Ohm RMS Power: 1 x 350 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 650 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 1000 Watts @ 13.8 Volts
2 Amps Bridged 2 Ohm RMS Power: 2000 Watts
Frequency Response: 20Hz - 500Hz
Damping Factor: >500 @ 100Hz
S/N Ratio: >100 db
Minimum THD:
Dimensions: 25" x 9.2" x 2.12"
FEATURES:
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage Transistors
Fully Adjustable Low Pass Filter 50-150Hz
Fully Adjustable Bass EQ 0-18dB @ 40Hz
Fully adjustable Subsonic Filter 11-47Hz
Adjustable Input Gain 170mV-8V
Phase Shift Control 0-180
Ultra Reflective Chrome Top Cover
Subwoofer Controler Included 18dB @ 40Hz
Bridge Link-Multi Amplifier Master/Slave Control
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitry
Lucite Encapsulated Terminals
connersdad19
connersdad19
Logan, Ohio (43138)
connersdad19
