Cadence SeaQua SQA-4100 4 channel marine-grade amplifier
Wingman0121
Cadence SeaQua SQA-4100 4 channel amplifier
(right-click and select view image for large pictures)
Powerful 4 channel amplifier, 100 watts RMS x 4 into 4 ohms and 200 watts RMS x 4 into 2 ohms. Requires an external 80a fuse(not included). Cosmetically it is in good condition besides a few small marks on the amp and by the mounting feet. This is marine-grade amp which means the amp has an epoxy-coated circuit board and silicone gaskets all around the case.
I bought this amplifier about 3 years ago and used it in my car to power 2 pairs of Pioneer Premier component speakers. I disconnected the RCAs to the channel 3 and 4 to test another amp, plugged them back and those two channels stopped making any sound after that. Not sure what happened, I switched RCAs from the other channels and didn't make a difference, switched the amp to get signal from channel 1 and 2 and still nothing. I called Cadence(they do repairs on their own amps) and two local repair shop and all three said it's a simple repair and shouldn't cost more than 50 bucks... something in the input circuit they said. Channel 1 and 2 works perfectly and I've been using just those two channels in my car for the past 9 months. Nothing looks burnt inside and the amp doesn't get hot on idle.
$80 shipped or trades
USPS, original box and manual included.
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
Wingman0121
