Buying an Alpine MRD 605 for $115. Is it a good deal?
joelx21
As the title says... is $115 a good deal? Below I have pics of the amp and info on it.
Thanks,
Joel
Alpine Mrd-M605
* Mono subwoofer car amplifier
* 400 watts x 1 at 4 ohms
* 600 watts RMS x 1 at 2 ohms
* Internal, variable-speed cooling fan
* MOSFET power supply and output stages
* STAR Topology for cleaner sound
* Bass Engine® features:
o Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
o Selectable subsonic filter (off, 15Hz, or 30 Hz)
o Parametric EQ variable from 30-160 Hz, ±12 dB
o Bass Compensator enhances low-end definition
* Top-mounted digital control center with cover
* CEA-2006 Compliant
* Preamp outputs
* Time correction 0-10 milliseconds in 0.1ms steps
* Phase adjustment 0-180
* Turn-on delay
* Requires 4-gauge power and ground leads
* Extra-large terminals
* Fuse rating: 30A x 2
* Dimensions: 11-7/16"W x 2-1/4"H x 9"D
i use to have one of those on a pair of id12's. it was a solid amp and sounded good to me. that was 5 years ago so i payed more for the amp back then but that seems like a good deal to me
I've heard great things about these amps, but since they were discontinued a while back, I'm not what to value it at. Also, I don't know how well they usually hold up.
Anybody else have any input??? I'm leaving shortly to buy it and I would really like to know if it's a good deal before I pull the trigger on this.
joelx21
joelx21
So Cal
joelx21
