I'm putting the TypeR12s in within a week or so. It's been a long time since I bought a new sub, how long should I keep the tunes low to give the woofers time to heat up? I wasn't sure if it was like, 10 minutes, or 10 days.
why would you ever want to do that anyway?Isn't it a bit safer to gradually do it, versus burping them @ double their RMS for the first time they ever light up?
It was just an extreme comparison.why would you ever want to do that anyway?
just play them normally, theyll be fine. your sub wont blow if you play it within its power handling capabilities.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Your "play them like normal" is burping them at twice their RMS?Isn't it a bit safer to gradually do it, versus burping them @ double their RMS for the first time they ever light up?
Yes, the soft parts will loosen up. However, you don't need to do any sort of "break in period" for this to happen. It will happen over time with regular and normal use. And, frankly, if you were wanting to break in a sub, playing it at a low level would actually be counterproductive as the only way to loosen them up is to actually use them.It was just an extreme comparison.
I just always thought if you played the sub lower when it was in its first few days of life that it would be a bit better for it because the surround would grow softer.
Yeah, I guess I just wasn't too sure then. I just thought to START breaking it in is where you were recommended to take it easy. Meaning, I wasn't talking about fully breaking it in, just the start of it really... I somehow had 2 days stuck in the back of my head, for what it's worth.In order for it to break in, the sub actually has to move a fair amount to stretch the mechanical suspension. Playing it at low volume will do very little (if anything) to break in the sub.
Either use the sub normally and the sub will gradually break in or run a low-power, low-frequency test tone through it in a vice clamp (no enclosure) over night ... Typically, it'll take ~50 hours of decent excursion to fully break in ... So, 1 hour a day of normal use will still take a month and a half to fully break in ...
I'm confused. Did you use this same Alpine head unit with the IDMAX? Why would that of changed anything? Sounds kind of stupid, like Alpine was blocking the sub output? *unsure*i just got my type-r the other day and to tell you the truth, i was quite dissappointed since i once had a sealed IDMAX set up in comparsion. My new R is in a 1.8 net cubic feet box tuned to 33hz running off my HIfonic's bx1500d amp. I just got my new Alpine headunit too but it wasn't until i actually played around with the bass engine pro when the Type R really shined. i spent the whole day today looking thru the manual and tuning the sound. The type r sounds just as good as my previous sealed Idmax but it was LOUDER. I could crank it up for days and still hear no straining from the sub. My sealed idmax would've showed signs of stress at this point. Alpine did a great job on the new R. As for breaking it in, I've just playing it normally.
lmao.Just to give you an idea of what it takes to break a sub in, here's an example ...
http://www.vikash.info/audio/xls10/index.asp
Take a look at the video - http://www.vikash.info/audio/xls10/830452_run_in.avi
It took ~50 hours of that for it to fully break-in ... If the driver is only moving a couple mm each way, it's not going to do much to break it in ...
Like I said.....depends on the sub. Some subs actually do higher numbers straight out of the box rather than being broken in, in which case that's exactly what someone would want to do.Bottom line is, don't compete and burp a sub the second you get it,
Pretty much.however breaking it in for daily driving is next to useless as long as you're reasonable with it (aka, no burping, competing, etc). Right?
