this sub is brand new only ran 600w to test it for about 5 minutes. Lemme know guys i want to downgrade to 2 bada$$ 10's instead. not looking for trades. Thanks pics can be found here http://forums.caraudio.com/vb/showthread.php?t=135169 , and specs are below.
For Sale: MA Audio HK12X2 160.00+actual shipping
SPECS:
1500W RMS
3000W MAX
Sensitivity: 88.9dB @ 1w/1m
Mounting Depth 8"
Mounting Diameter 11"
Vented Box: 3.0 cu/ft
Port: 48 sq/in 14.5" Long
Sealed Box: 1.5-2.25 cu/ft
Dual 2 Ohm
Aluminum Round Wire Voice Coil
Hi-Temp Kapton Voice Coil Former
400 Oz. Double Stacked Strontium Magnets
Patented Thermo-Cooling Motor Structure
Bumped Back Plate for Max Excursion
High Roll Triple Layer Ribbed Surround
Double Layer Progressive Spiders
Dual Layer Pressed Carbon Fiber Cone
Ultra Strong Carbon Fiber Dust Cap
Rubber Sealant Gasket
T/S PARAMETERS:
FS (HZ) : 31.89
QMS: 5.701
QES: .360
QTS: .338
VAS(LITERS): 51.238
REVC(PARALLEL-OHMS) : 1
SPL @ 1WATT / 1 METER (DB) : 88.9
X-MAX LINEAR PEAK-PEAK(MM) : 70
LEVC AT 1K HZ (MH) : 1.059
SPECS:
1500W RMS
3000W MAX
Mounting Depth 8"
Dual 2 Ohm
T/S PARAMETERS:
FS (HZ) : 31.89
QMS: 5.701
QES: .360
QTS: .338
VAS(LITERS): 51.238
