Sold Brand New In Box Solid Audio F2500D
infamous_e46
hArRy_DaNgLeRs
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
looking for 385 shipped conus
You can always just wire up a switch to your remote wire. Kill the whole thing instead of having to adjust the gain (I prefer to set mine with an o-scope and leave it alone).
OP, you have a PM, and bump for you.
I WOULD LOVE THAT AMP BUT I NEED MONIES TO FIX MY HONDA //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Wasn't trying to be a smart arse ... Really curious if there's a difference, or why killing gain is better, or whatever.
Nah I never thought you were tryin to be. I've just gotten use to this way. If I used my remote like I should, then I wouldn't have to worry about it. But 90% of the time, the **** thing is in my door handle...... //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
rosrock
