BRAND NEW Alpine - 12" Dual-Voice-Coil 4-Ohm Subwoofer question
i just recently bout a Alpine - 12" Dual-Voice-Coil 4-Ohm Subwoofer with Alpine MRP-M650
Mono subwoofer amplifier
how should i set my gain and LPF so idont blow the sub. by the way i have a Kenwood KDC-MP 238 head unit
the specs for each are listed below:
sub...
# Handles up to 1500W peak power (500W RMS)
# KEVLAR-reinforced pulp cone, oversized parabolic dustcap; HAMR surround and concealed mount gasket (KEVLAR is a registered trademark of DuPont)
# High-strength brass voice-coil bobbin; 50mm voice-coil diameter
# Dual progressive oversized Nomex spiders with integrated tinsel leads for added stability
# Dual stacked magnets
# Custom cast aluminum frame with integrated heat transfer plate; radial vented VC heat sink and airflow management system
# 11" top-mount diameter; 7-3/4" top-mount depth
# Magnetically optimized motor structure
# Frequency response: 25Hz - 500kHz
# Sensitivity: 85dB
# Impedance: 4 ohms
amp...
# mono subwoofer car amplifier
# 400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz, 24 dB/octave)
# tuned Bass EQ (0-12 dB bass boost at 50 Hz)
# subsonic filter (24 dB at 15 Hz)
# MOSFET power supply
# CEA-2006 compliant
# STAR Topology (minimizes internal noise and prevents ground interference)
# speaker- and preamp-level inputs
rientile
rientile
West Palm Beach, FL
rientile
