Brand new 3/0 welding cable- 25' roll
danno14
1. Product: 3/0 copper welding cable- Eupen Flex Use H07 RN-F 1X95 Wire. Go here for specifications:
http://www.hitechcontrols.com/cables/rubber_welding_cables/rubber_welding_cables/h07_rnf.html
This is HEAVY duty cable, but for how thick it is, pretty darn flexible. Individual strands are fine, as indicated by the F in the part number.
2. Specs: 3/0 copper, Rubber outer jacket cable, 95mm cross section (copper)
Temperature Range
-30°C to +60°C (-22°F to +140°F)
Permissible Operating Temperature
at conductor +60°C/+140°F
Nominal Voltage U0/U 450/750 V
In case of protected and fixed installation
U0/U 600/1000 V
Permanent Tensile Load
Max. 15 N/mm²
Minimum Bending Radius
For fixed installation 4x cable Ø
For guiding over roller 7.5x cable Ø
During winding on drums 5-7x cable Ø
Copper conductor fine wire stranded, bare to DIN VDE 0295 cl. 5, BS 6360 cl. 5, IEC 60228 cl. 5 and HD 383
Rubber conductor insulation EI4 to DIN VDE 0282 part 1
Insulation thickness to DIN VDE 0282 part 4
Resistant to
Ozone
Weather
Oil resistant
Test according to VDE 0482-332-1-2, DIN EN 60332-1-2 / IEC 60332-1 (equivalent DIN VDE 0472 part 804 test method B)
Ozone resistant of the insulation to DIN VDE 0472 part 805, test method A or part 805 A1, test method C
Oil resistant - Test according to EN 60811-2-1
3. Description/Condition: Brand new off the roll. I may have access to more, but not much. PM me if interested in this roll or other.
4. Price: : Will ship 25' via USPS to the lower 48 states, included in the price of $100
5. Pictures:
danno14
danno14
Pac NW
fieryhooligan
