Brahma MKII power handling and box specs?
alxmlr789
6>5
I just acquired a Brahma in a trade and can't find too much information on box specs, or what their rated RMS is.
I watched some vids on ROE, and it looked like the average was 2.0-2.5 at 28-32 hz
power wise was round 1000.
Can anyone give me some other info?
Thanks.
was 1600rms but alot of people burned there coils doing that and pushing them that far...
They sound good on 1000-1300rms daily
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
Re2 0.75 Ohms parallel
Le3 0.45 mH parallel
BL 15.9
Sd 749 cm2
Xmax 28mm one way linear
Pmax4 1600W RMS, 4800W peak
NOTE: Power rating is thermal only! It is NOT a power requirement; typically you get full output with significantly less power than the rating.
SPL5 87.6 dB @ 1W, 1m
Diameter 15.5"
Cutout 14"
Depth 8.25"
Volume 0.18 cubic feet
Weight 41 pounds
Application
Sealed Car 1.25 to 2.5 cubic feet
Vented Car 2 to 3.5 cubic feet tuned to 28 Hz
Sealed Home 1.5 to 3 cubic feet
Vented Home 5 cubic feet tuned to 20 Hz
Infinite Baffle CAR: Yes HOME: Yes
Parameters
Fs 26 Hz
Qms 5.5
Qes 0.51
Qts 0.47
Vas 113 liters
Znom 1 Ohm parallel
BL 15.9
Sd 749 cm2
Diameter 15.5"
Cutout 14"
Depth 8.25"
Weight 41 pounds
Application
That for the 15?
alxmlr789
6>5
alxmlr789
FL
lilpnoybreaker
