bout to just give up
Best thing to do is to get a drill tap and dye set. Can get a cheap Craftsman set at Sears. Then go to Ace hardware, find some allen screws a bit bigger than your current ones, run them through the dye set and find the size. Once you do that, set the tap up and re-tap the hole to the new size. When you tap it, screw through once and out once. Then run a small wire brush through your work and you will be good to go. Will cost you less than $20 bucks then you will have your amp fixed, a solid, handy tool set, and no loss time from sending it back to eD. They **** anyway. My eD-15A failed from a design flaw and I got ****ed on the deal by them wanting to hit me up for $150 to glue the shit back together. Lloyd has the shit right with his avatar... Good luck with the tapping man.
you must have been a tool or trying to pull a scam or something... my 15A got
replaced with a brand new 16Ov.2 in less than a weeks time...
nice try spitting sh1t about a good company... liar...
but if you are wanting SPL from 3 cubes- you are in a tight spot sir.
I was only able to fit ~3 cubes also, till i got off my lazy *** and actualy did something about it instead of complaining and saying im gonna give up. Now i can fit around 5.8 cubes after sub and port displacement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Tap and die set. You drill a hole in the middle of the allen screw head and then insert a reverse threaded screw then screw it back out. Get a new allen screw and you're done!
sooooo ur sayin im a lazy ****? u must not have a ****ing clue man. for reali have tried about all i can to get a box in my trunk and i THINK i can pull 3 cubes AFTER displacement which is shit. if u care to chime me in on how to do it and get a bigger box im all ears. and until you have worked with an 05 mustang dont speak shit!
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
saywhat?
