Boston GTA-800M for a high power 4 channel
  • 2
WashYourWinky
The Pilot
Boston GTA-800M
Mechanical 10/10 Cosmetic 9/10
Will come in the original box.
Looking to trade for a high power 4 channel amp.
Specs:
GTA Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
MOSFET power supply
Bass Remote Details (Boston Acoustics GTA-RSL required and sold separately)
LED power and protect indicators
Boston’s Q-Tune™ circuitry for simple bass output optimization
Mono channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
SST™ (Symmetrical Signal Topology) system uses balanced asymmetrical inputs for noise cancellation
Recessed control panel for clean installation
Wrap-around heatsink design for ample cooling in multiple mounting positions
IMS™ (Integral Mounting System) reduces the amplifier footprint
All input/output connections are located on one side of the amplifier to ease installation and wire management
Optimal angled speaker and power blocks for easy wire connections
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-150 Hz, 12 dB/octave)
Subsonic filter (10-50 Hz, 12dB/octave)
CEA-2006 compliant amplifier
Frequency response: 10-150 Hz
Dimensions: 8-3/8"D x 12-1/2"W x 2-3/8"H
Best of luck on the search of these Gems 👀 👀 💩
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
    May 18, 2024
    May 18, 2024
