Boston Acoustics powerhouse made in Italy GT-28
gentlejax
Item(s) for Sale:Boston GT28 2 channel and new Knu Concepts ditro block
Item(s) Description/Condition: Boston has some scratches but could easily be painted. solid powerful made in Italy amp. the last Boston amps were made in malaysia.
I would beat up my sub with this but then my car electrical cant take this on top of the other amp I have together.
. Specs:2-Channel High Current Amplifier
2 ohm Mono Stable
Advanced cooling allows varied mounting positions
Adjustable feet for varied mounting surfaces
Screw-down security cover protects tuning controls
Terminals accept bare heavy-gauge wire
RMS power Rating:
14.4VDC:
250 watts x 2 chan. @ 4 ohms
450 watts x 2 chan. @ 2 ohms
900 watts x 1 chan. @ 4 ohms
1250 watts x 1 chan. @ 2 ohms
12.6VDC:
200 watts x 2 chan. @ 4 ohms
350 watts x 2 chan. @ 2 ohms
700 watts x 1 chan. @ 4 ohms
1100 watts x 1 chan. @ 2 ohms
Adjustable input sensitivity: 0.2 - 5 V
Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
Variable Q Control: 0.7 - 1.2
Power and Safe LEDs
Recessed rca Inputs allow clearance for tight mounting locations
Optional subwoofer level control not included
Dimensions: 22" L x 9" W x 2-1/2" H
100 amps of fusing and these amps do every bit of the rating and then some. I am told these are impressive. it has 2 positive and 2 negative connections.
throwing in a new knu concepts terminal block
Price: $200
gentlejax
gentlejax
Bossier City, La.
gentlejax
