Boston GT 42 4 channel amp
Cosmetically: 6 of 10 (plastic on left side of amp seems to have a small crack, normal scuffs on top, and screws holding the plate that covers the control panel are bent, none of this affects the performance)
Performance 9.9 of 10 (just because its used, tested it out fully in my car yesterday and it works and has some serious powahh, for those who don't know about the older Boston GT amps, you wont find many amps that can beat it)
4-Channel High Current Amplifier
2 Ohm Mono Stable
Advanced cooling allows varied mounting positions
Adjustable feet for varied mounting surfaces
Screw-down security cover protects tuning controls
Terminals accept bare heavy-gauge wire
RMS Power Rating:
14.4VDC:
100 watts x 4 chan. @ 4 ohms
150 watts x 4 chan. @ 2 ohms
300 watts x 2 chan. @ 4 ohms
450 watts x 2 chan. @ 2 ohms
12.6VDC:
75 watts x 4 chan. @ 4 ohms
120 watts x 4 chan. @ 2 ohms
220 watts x 2 chan. @ 4 ohms
350 watts x 2 chan. @ 2 ohms
Adjustable input sensitivity: 0.2 - 5 V
Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
Variable Q Control: 0.7 - 1.2
Power and Safe LEDs
Recessed RCA Inputs allow clearance for tight mounting locations
ummm.... 165 obo....pretty flexible on price or trades for aura stage 2 amps and subs
I got u homez
http://www.caraudio.com/forums/wanting-trade-wtt-car-audio/540382-boston-acoustics-gt42-4-channel-amp.html#post7982527
2 Ohm Mono Stable
RMS Power Rating:
14.4VDC:
12.6VDC:
Power and Safe LEDs
I got u homez
