Boston Acoustics GT-5750 5 channel
Item(s) Description/Condition:Like new. was used by previous owner short period. not a mark on it. bought it off here actually from Indytrucks. it could pass for new easily.
Price:$200
* 5-channel car amplifier
* Q-Tune™ technology combines sophisticated crossover adjustments with Q-Control settings to seamlessly transition rear bass to the front sound stage
* High efficiency and output stages delivering increased power into lower impedance and maximum dynamics and transient response
* DualMode™ High-current, high-power design
* 1-ohm Stereo / 2-ohm mono stable
* Advanced fan cooling allows varied mounting positions
* Fully Adjustable crossover highpass and lowpass crossover for exact integration of speakers and subwoofers
* Low-profile height 2 3/8"(61mm) allows installation in tight locations
* Adjustable mounting feet accommodate varied mounting surfaces
Number Of Channels:
5 Channels
Power @ 4-ohm (CEA-2006-A):
75 Watts x 4, 200 Watts x 1
Power @ 2-ohm (CEA-2006-A):
100 Watts x 4, 375 Watts x 1
Power @ 4-ohm (12vdc)
50 Watts x 4, 275 Watts x 1
Frequency Response (-3dB):
10Hz-95kHz
Signal to Noise Ratio (A Weighted):
>100dB
Lowpass Crossover:
12dB / 24dB Adj. (50Hz to 350Hz)
Highpass Crossover:
12dB Adj. (20Hz to 250Hz)
Q-Tune:
Adj. HP Q (0.707 to 1.6)
Height:
2 3/8” (61mm)
Width:
22 1/4" (566mm)
Depth: (w/Mounting Feet)
9” (229mm)
stuff pictures by gentlejax - Photobucket
Price:$200
Number Of Channels:
5 Channels
10Hz-95kHz
>100dB
Lowpass Crossover:
Highpass Crossover:
Q-Tune:
Height:
2 3/8” (61mm)
Width:
22 1/4" (566mm)
9” (229mm)
