boat bulids?
pbnj22
anyone have any pics or vids of their boat installs?
I have an old system in mine but i plan on beefing it up a bit and it seams pretty easy as there is tons of room for wiring and what not. Just looking for some ideas. anyways boat is a 22 foot 1986 Thompson 305 4 barrel inboard 230 horse. Basically a huge ski boat with a small cuddy ill take pics when i get a chance.
anyways just looking for some ideas and eventually some equipment.
The back bench is pretty wide so i was thinking maybe putting 2 speakers and a sub all facing out using the same front plate then building separate boxes for each behind each speaker underneath the bench if that makes sense. Then maybe 2 more speakers in the side upholstery one by the driver and one the shotgun seat. just not sure where to mount the amp. Probably under the dash somewhere.
[quote name='kushy_dreams']A lot of those marine engines use small (<100a) alternators so you will max out stock electrical systems pretty fast on a boat.
@agarabaghi ; put some high powered 10s in his mastercraft ski boat[/QUOTE]
I dont plan on doing much lol... maybe 4 speakers at 50 to 100 watts each not even sure if ill be running a sub unless i can find a cheap amp to push around 300 watts
well on a boat you'll need more than 300 watts if you wanna hear it.the bench seat is good if done right ,rino line the box too it will help the box to stay waterproof.also no speakers in the bench if you are doing subs there.still need pics
pbnj22
pbnj22
Duluth MN
snoopdan
