Sold BNIB JL AUDIO 10W3V2 and JL Audio A1200 mono amp
N2Audio4life
(SOLD)Both Brand New in Box both bought from a local authorized dealer comes with 1 year warrenty from JL. Will get pics as soon as I can $125+shipping for both
1. JL Audio 10W3v2-D6 10" DVC Sub $125+shipping Sold local
Key Features
* Nominal Diameter: 10 inches (250 mm)
* Continuous Power Handling: 300 Watts
* Voice Coil: 2.25" diameter, 4-layer, Kapton former
* Dual 6 ohm Voice Coils
* Sealed Enclosure Range: 0.60-0.90 cu.ft. (17.0-25.5 liters)
* Ported Enclosure Range: 1.00-1.50 cu.ft. (28.3-42.0 liters)
* VRC Technology
* Elevated Frame Technology
Specifications
* Free Air Resonance (Fs): 29.3Hz
* Electical"Q" (Qes): 0.547
* Mechanical"Q" (Qms): 9.50
* Total Speaker"Q" (Qts): 0.517
* Equiv. Compliance (Vas): 48.4 litres
* One-Way Linear Excursion (Xmax): 0.513" (14.7mm)
* Efficiency (1W/1m): 85.5dB SPL
* Mounting Depth: 5.75"
* Mounting Hole: 9.125"
2. JL Audio A1200 Mono Amp $160 shipped - SOLD LOCAL
Rated Power 12.5 V: 120 W RMS x 1 @ 4 ohm 200 W RMS x 1 @ 2 ohm
Rated Power 14.5 V: 175 W RMS x 1 @ 4 ohm 275 W RMS x 1 @ 2 ohm
THD at Rated Power: 12.5V: >0.08% THD, 20 Hz - 20 kHz 14.4V: >1% THD, 20 Hz - 20 kHz
S/N Ratio:
Frequency Response: 10 Hz – 25 kHz (+0, -1dB)
Slew Rate: ± 22V / µs
Input Range: 200mV – 8V RMS
Dimensions (L x W x H): 9.80 in. x 9.25 in. x 2.50 in.
Differential-Balanced Inputs
Advanced Rollback Protection System
Variable High- and Low-Pass Filter
Switchable Bass Boost
Absolute Symmetry™ Class-AB amplifier design
MOSFET Power and Output Stages
Speaker- and Preamp-Level Inputs
Preamp Outputs
N2Audio4life
N2Audio4life
harriman, TN
N2Audio4life
