I’ve highlighted in yellow the damaged area. It looks very minor and I would think that it would be an easy fix. This is the last of the great SQ amps by Soundstream. Amp comes with original box and manual.
Specs at 13.6 volts = 150x2 at 4 ohms, 300x2 at 2 ohms, and 600x1 bridged at 4 ohms.
RUBI™ (Rapid-Use Branched Impulse) proprietary power supply topology
STACT™ (STabilized Apex Current Topologe) Reduces power supply stress by 50%
Trident™ amplifier protection topologe
Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
Hawkins Bass Control™ Proprietary bass equalization topology
IDI™ (Intelligent Distress Indicator) gives visual indication of amplifier protection status
Harmonic Bass Alignment™ Produces tighter, more accurate bass
Fully regulated MOSFET power supply
Triple Darlington Output Circuitry
BIP™ Bias Input Protection
Rail Stabilization Protection Circuitry
Bi-Linear selectable two-way crossovers for amplifier and line output
Continuously Variable High and Low Pass Crossovers
Balanced line Inputs for Highest level of Noise Rejection
Vortex Induction Fan Thermal Management
Platinum RCA Inputs and Outputs
Platinum 4-gauge Power Connectors
Tri-mode operation
STACT™(STabilized Apex Current Topology) Reduces power supply stress by 50%
Power Bandwidth: 10 Hz - 50 kHz
Total Harmonic Distortion:
S/N Ratio: 115dB
Input Sensitivity: 0.15~12.0 Volts
Input Impedance: 10k Ohms
Load Impedance: (stereo) 2 - 8 Ohms
Load Impedance: (bridged) 4 - 8 Ohms
Supply Voltage: 11 - 15 Volts
Damping Factor: >500
Slew Rate: >50 V/μS
Hawkins Bass: Up to +18dB Boost @ 30Hz~100Hz
Crossovers: 12dB/Octave
Crossover Frequency: 50Hz-5kHz
PRICE: $85 SHIPPED ANYWHERE IN THE USA.
Highlighted damaged area:
Nice clean layout of the board:
Tri-mode operation
S/N Ratio: 115dB
Slew Rate: >50 V/μS
