Sold Black Friday Sale!!
ssackett
Evo Audio
Sale will end on Monday.
Well here we go...
The info on the sub shows its load and rms. Please done ask for specs.. I dont have them.. I can tell you these are one of the better sounding subs I have heard. They have 4 layer round wire alum coils and 2 med spiders that are clamped and spaced. If you want a matching pair reference the code on the motor.
Cool little budget subs..
Actually have 10 of these.. Specs are on the tag.. Price $57 + shp 15lbs
1 sub.. Specs on tag.. $20 + shp & 12lbs
50 of these budget 12's are availible.. Specs are on tag..
EDIT- These are rated at 300wrms
Specs
Znon [ohm] 4.000
Revc [ohm] 4.190
Sd [sqM] .0530
BL [TM] 15.250
Vas [Liters] 84.947
Cms [uM/N] 211.457
Mms [grams] 131.896
Mmd [grams] 124.880
Fi [Hz] 29.366
Fo [Hz] 30.137
Qms 10.59
Qes0 .4500
Qts0. .4320
Xmx [mm]6.604
(2.83) SPL [dB]91.340
14 of these little beast 10's lol...
10"
Znon [ohm] 4.000
Revc [ohm] 6.700
BL [TM] .81823
Vas [Liters] 39.325
Cms [uM/N] 254.297
Mms [grams] 113.168
Fi [Hz] 29.226
Fo [Hz] 29.668
Qms 6.778
Qes 0.3260
Qts .3200
SPL [dB] 87.370
xmax 9.5mm
This is pretty crazy to though.. LOL!!
Ah why not.. Any size sub you want with this Fully loaded BTL motor..
3 stiff spiders with double sewn leads.. More spiders at no cost if you want, 8 layer flat wound coil with 2.25" ww in D1 or D2. 12 spoke basket for 12"-18" pr you can use 6 spoke for the 18".
18" 3vc with 7" indent
12" 2.5vc. See tag for spec
15" 4vc.. 2 different CF weaves and paper.. Also has a aluminum honeycomb reinforced cented. VERY STRONG CONES!
10" 3vc.. CF cone. Only have 6 of these for sale guys.. - SOLD!!!
D1 4" VC's 4.2" OD ID I need to measure. 2.25" WW.
Q1 3" VC 2" WW 3.3" OD
Silver top plate TRF motor
MOAB motor.. Black top plate TRF clone..
12" 3vc.. 7" indent with higher roll 20+ of these.
15" 3vc.. 7" indent
12" 3vc with a higher roll lol...
Random stuff I didnt get to log..
1 6.5" Comp set.. Have no specs but heard these in a car at the shop and they sounded clean.
BNIB Directed D1200.. 600wrms..
Ok.. I didn't have time to log these and get specs.. all subs will do 1000wrms. Any sub under this list ill do for
ssackett
Evo Audio
ssackett
CA
michaellane
