batt. ?
lets see... get a +/- side mount battery post for each batt and get 4 ring terminals, clamp terms on wire, screw terms on post.
Or... you could get 4 battery terminals and hook them on top and cut back the rubber on the wire and screw the wire into the battery terminals. 1st is much cheaper...
run the power wire from the front battery to the rear battery and ground the rear battery to the chassis in the rear somewhere. Try to keep the ground wire as short as possible less resistence
ok so i have my batt. under my hood and then run my power wire back to the second batt. then from my second batt to my amp....the ground sec batt to the chassis?
perrydog
perrydog
g-ville
perrydog
